Egr valve stuck to intake manifold
Old Jan 9, 2023 | 5:25 PM
Gabby290's Avatar
Default Egr valve stuck to intake manifold
Gotta rusty egr valve needing replacing, nut rounded off one of the studs, left side. Barley enough space to get a socket underneath the valve itself, let alone a rachet. I'm figuring the torch will damage anything around it, and not trying to make it worse with vice grips. Any suggestions, please and thank you?
Old Jan 10, 2023 | 7:45 AM
Welcome from Florida. Soak it in Blaster and tap on it while doing so. You don't have much of a choice but to try vice grips. Use the Blaster first!
Old Jan 10, 2023 | 9:26 AM
Gabby290's Avatar
Yeah I'm from Illinois so doesn't surprise me she's stuck on there. Im going to pick up a bottle of P.B. today cause wd-40 just doesn't cut it. Also gonna run a vacuum tester to make sure the egr is stuck or not. Thanks for the advice
jimmythesing@gmail.com
Jul 6, 2021 1:26 AM
Sooner13
1988 - 1998 (GMT400)
May 16, 2018 11:59 AM
Taylor1
Dec 5, 2010 4:39 PM
miked
May 23, 2010 10:53 PM
slater
Aug 10, 2008 8:14 PM
