Electrical help 1995 C2500 7.4 HVAC/wiper motor
Old Nov 28, 2019 | 9:45 AM
DavidJr's Avatar
Default Electrical help 1995 C2500 7.4 HVAC/wiper motor
I have a 1995 C2500 2wd Auto with the 7.4l. The blower motor will not run and the wiper motor will not run. As of today I’ve replaced all fuses, the blower motor, the blower resistors, and have ordered a new hvac control module. I’ve replaced the multifunctional switch and the wiper motor.
These two problems started after a mechanic shop pulled the transmission to replace the clutch plate.
I’m trying to find the exact wiring harness layout to figure out what wire:wires could be related to the 2 issues.
any help would be greatly appreciated
Old Nov 28, 2019 | 9:55 AM
Irish_alley's Avatar
I'm here for the party
well they might have pinched some wires between the engine and trans. might have been enough to break the wires but not cause a short
Old Nov 28, 2019 | 10:02 AM
DavidJr's Avatar
that’s what I’m thinking also. I’ve been going through the schematics from Chilton trying to isolate which wire that could directly cause both issues.
the multifunctional switch does function the blinkers and hazard lights just not the wiper motor. So the whole switch is not affected just the wipers.
thank you for reply
Old Nov 28, 2019 | 10:16 AM
you shouldnt need a schematic. just look or run your hand around behind the engine and feel for any trapped wires or wires that could have been pinched
Old Nov 28, 2019 | 3:50 PM
DavidJr's Avatar
found the issue with he common ground was damaged
Old Nov 30, 2019 | 1:30 PM
glad you got back with the update
Gallexy
Uplander
20
Dec 26, 2019 8:21 AM
wsmutch
Jun 10, 2010 10:17 AM
Mymarine68
Feb 25, 2010 3:41 AM
wbetheajr
Jun 20, 2008 10:29 PM
Burb
Aug 12, 2007 8:44 AM
