engine oil cooler delete
Old Dec 6, 2025 | 10:22 AM
brit644's Avatar
Default engine oil cooler delete
1995 K2500 454.
Suffered the dreaded plastic clip failure. Installed rebuilt 454, didnt reinstall cooler lines. Has the horizontal filter [it's 4x4 of course] Have only driven maybe 500 miles in 4 yrs since the swap. While warming it other day [was maybe 25 degrees] noticed oil pool rear of pan [never had an oil leak of any sort save for the clip failure] Little research have done appears not an uncommon occurrence. [obviously theres inherent problems with the design]
What is surprising is the severity of the leak. Pulling into the driveway a literal steam of oil appeared. Thankfully once not turning over it ceases to leak.
Advice/ideas on permanent solution would be much appreciated.
Keith
[img alt="Only leaks while motor running
"]https://cimg6.ibsrv.net/gimg/chevroletforum.com-vbulletin/1500x2000/oil_filter_housing_f925c01ffef12c735cd02d93065b4f4 0f2efd761.jpg[/img]
Gord83
Dec 2, 2016 4:35 PM
ChevyChic
Oct 4, 2009 12:04 AM
DEEP
Astro
May 23, 2008 10:30 PM
trush
Jan 1, 2008 9:27 PM
