Erratic fuel gauge
Old May 1, 2019 | 9:28 AM
bstone4964's Avatar
Default Erratic fuel gauge
Hello-
My 96 has an erratic fuel gauge. I have read that it could be a couple things- 1, that the sending unit is going bad, and 2, that the stepper motor behind the gauge itself is going bad. Also heard that there is a baffle in the tank that keeps the sloshing to a minimum, which I guess would help the gauge from bouncing.
I am leaning toward the sending unit being bad, simply because it isn't randomly bouncing around, but it doesn't appear accurate. It showed 3/4 of a tank the other day, and when I filled it up, it took 11 gallons- and the gauge went well past full. Not sure what size my tank is, but if it showed 3/4 and I put in 11 gal, then that would mean a 44 gal tank- and I think these only came with either a 25 gal or a 34 gal tank.
Any thoughts?
Thanks!
Old May 4, 2019 | 8:40 AM
bstone4964's Avatar
Anyone? Anyone?
Old May 4, 2019 | 12:43 PM
Almost all the time, it is the sending unit that is bad. GM did have problems with the stepper motors but that was 03-06. The ones in 96 were pretty reliable.
Old May 4, 2019 | 1:37 PM
bstone4964's Avatar
Thanks for the response. My son had a 2001, and I think we put at least 2 pumps/sending units in that one. Pain in the backside, but at least I know what I'm doing.. probably a good idea just to replace pump and sending unit anyway, since I don;t know how old this pump is..
Thanks again-
Brady
Old May 5, 2019 | 9:28 PM
Irish_alley's Avatar
I'm here for the party
they arnt too hard to replace if you have someone to help. just unbolt the bed unhook the filler neck/ground and tail light wires then lift and move it down a few feet or a car lift works real good
