Fast Blinking Rear Turn Signal
Old Oct 11, 2023 | 9:10 PM
blueseasons's Avatar
Default Fast Blinking Rear Turn Signal
My experience tells me its typically a loose or burnt-out bulb. However. The bulb filament is good. When the relay fails. The bulb typically stays lit. Is that accurate?
Old Oct 13, 2023 | 4:04 PM
Rstone's Avatar
Default Got It
Originally Posted by blueseasons
My experience tells me it’s typically a loose or burnt-out bulb. However. The bulb filament is good. When the relay fails. The bulb typically stays lit. Is that accurate?
Over heated brake light bulb. I crushed the old bulb. Removed it . I put in a new bulb and all good.
Old Oct 13, 2023 | 4:09 PM
  • bad bulb
  • corroded socket , connector, or wires
  • bad ground
Old Oct 19, 2023 | 5:16 PM
2001 chevy silverado's Avatar
the relay module likely has a single resistor that "matches" the correct resistance. if R is too high (ie corroded socket) the electronics flip to "fast blink".
Old Oct 19, 2023 | 8:16 PM
MLockheed's Avatar
Banned
Are both front and rear bulbs good? Usually when a front or rear goes bad, the other will also blink. Also could be a relay issue
Chevygirl97
May 31, 2019 10:22 AM
davemudra
Jan 27, 2016 8:21 AM
Yogi
Jan 27, 2014 1:56 PM
stimutaxed
Mar 3, 2011 10:50 AM
SabrToothSqrl
Oct 5, 2009 4:05 PM
