Frame Rusted
Frame Rusted
So I recently bought a 1998 1500 for really cheap, 147k miles, 4x4,etc. The only issue it has is this hold in the frame, was wondering if it's possible or If I should fix it, I'm in NYS so any hole in the frame will result in a instant fail to my knowledge
Edit: I bought as a winter beater originally but I've been told I should fix it since the body is in good shape and it has somewhat low milage. Unsure of how I should proceed
find a mechanic that will safety it...or at least tell you what then want repaired before they sign off on it. spend all that money and then no one wants to pass it. that part of the frame is critical support to the leaf spring shackle. I would be reluctant to sign off on if its not done perfect.
