High Idle on Cold Start-up
Old Dec 6, 2022 | 6:17 PM
95T'Hoe's Avatar
Default High Idle on Cold Start-up
I have a 95 Tahoe with the TBI 350 in it. I have a random high idle on cold start up. I cannot seem to figure it out. It is definitely not a vacuum leak. I put a scanner on it during the last start up and logged the data. The IAC is opening all the way and slowly comes down. Another thing I noticed is the BLM is commanding a lean condition. Any ideas?
Old Dec 7, 2022 | 7:30 PM
Gumby22's Avatar
1) IAC movement sounds normal for start up conditions.
2) Remove the air cleaner and check the injectors for leaking fuel during the fuel line priming at key on.
3) Check the MAP sensor reading KOEO - if it doesn’t read atmospheric pressure on live data (or voltage equivalent if using meter) it’s skewed and needs replacement.
4) Check the ECT at cold start - it should reflect ambient temperature within 5 degrees.
flh69
Apr 7, 2014 2:58 PM
moto762
Aug 4, 2013 5:59 PM
DCSCO
Jun 11, 2013 5:43 PM
sollucho
Mar 19, 2011 6:38 PM
91chevy57
Apr 30, 2010 8:43 PM
