High oil pressure
Old Jan 14, 2024 | 10:25 AM
flh69's Avatar
Default High oil pressure
Removed the oil cooler lines on my K2500 several months ago due to the lines leaking like a sieve. Had to use the adapter to change the position of the oil filter. My oil pressure has went way up according to my gage. It now appears to be using more oil than before from leakage somewhere. Any ideas to lower the pressure. I am using 10W-30 Mobil 1.
Old Jan 14, 2024 | 10:33 AM
Rednucleus's Avatar
What is the pressure reading; does it change hot vs cold motor? Are you seeing a visible leak on the ground??
Old Jan 14, 2024 | 2:26 PM
flh69's Avatar
The gage will peg when it's cold but does come down to about 45 when it warms up when running at highway speeds. It does drop to about 30 at idle when warm. I have not crawled under it but I am seeing some oil spots on the driveway towards the front of the truck. But I saw those spots with the leaking cooler lines before I removed them.
Old Jan 14, 2024 | 2:35 PM
Try a mechanical gauge to see if the readings that you are getting are accurate. You could have a faulty sending unit or gauge.
Old Jan 15, 2024 | 6:18 AM
flh69's Avatar
I don't think it is the gage. High pressure started immediately after removing the oil cooler lines. I did some web searches and other people have had there pressure increase after the removal of the oil cooler lines??
Sal Briseņo
Jan 28, 2026 10:02 AM
Thomas Neels
May 23, 2024 7:54 PM
Skibadc
2007 - 2013 (GMT900)
Sep 24, 2023 12:17 PM
chrisb0611
Jul 26, 2023 2:13 AM
thabilesfam0713
Feb 11, 2022 11:05 AM
