How do I fix DTC P1345 - cam crank synch failure
Old Feb 12, 2024 | 7:12 PM
FEandGoingBroke's Avatar
Default How do I fix DTC P1345 - cam crank synch failure
Timing:
new cam sensor (three times)
new distributor (bought by previous owner)
new crank sensor
new timing chain and gears.
cam crank synch failure: p1345
scan tool: Snap-On MT2500 old red brick-
I went a tooth forward, a tooth back because people think I’m retarded. I did it to appease them: no start either way.
Distributor and rotor are spot on as in the photos, starts but cam retard is up to 39 degrees. I slotted the hold down, I spread the finger tips to give me some physical advance. I got it to a minimum of 19 degrees, (once it was -7degrees but after swapping to another new cam sensor under warranty- I could only get 19)
factory values are -+ 2 degrees.
do is this a schitt distributor from China, or a PCM issue?
I’m stumped and need your assistance
97 350, 4x4 auto with ac.
Old Feb 13, 2024 | 1:08 AM
Thanks for the title upgrade. 😎
Old Feb 13, 2024 | 3:39 PM
Well looks like nobody has any thoughts on this.
so I just ordered a new distributor from Amazon from ac-billet with a lifetime warranty.
im starting to believe the reluctor on the distributor top shaft was installed incorrect by that guy over in Taiwan. This problem is a pain n the bottom. lol
Old Feb 13, 2024 | 3:41 PM
Gumby22's Avatar
If you’re not aware, cam signal needs to be checked at 1200 RPM.
Have you checked/verified any voltages at the cam or crank sensors?
Old Feb 13, 2024 | 3:50 PM
I have not checked the voltage to or from the cam or frank sensor. Not having a crank code I haven’t done that. If there was a ground loss the obdII system should pick up on that, same for cam sensor. Since no other codes are present I didn’t do the tests.
I’m going to start it again here in a few, hold it at 1200 for a few minutes while watching the data flow on my scanner.
there aren’t any cam adjustments I can make through the scanner in regards to the cam sensor, currently I have the non adjustable distributor pushed to the slop max and I’m sitting at -19 advance on the cam, rather that 30 when the distributor is in the OEM position. One tooth on this distributor is 3/4 the distance between the #1 tdc, and the #8 pickup stud in the cap. Same distance away from #1stud if I retard it a tooth.
DrummerBoy
1988 - 1998 (GMT400)
25
Feb 15, 2024 4:50 PM
JimOmaha
Nov 12, 2022 7:26 PM
jmeek4711
Nov 26, 2013 9:24 AM
KennesawCharley
May 16, 2013 11:40 AM
