Cam, crank, distributor don't match up
Old May 16, 2013 | 11:21 AM
KennesawCharley's Avatar
New User
Awaiting E-mail Confirmation
Default Cam, crank, distributor don't match up
1986 El Camino w/305 with 310k miles, all original. The original cam sprocket was nylon, which was cracked.
Would not crank and at TDC distributor pointedat #2. Firing order is: 1 2 7 5 6 3 4 8.
Replaced timing chain and gears w/double roller. With both marks at 12 o'clock, per the manual, the distributor still points a few degrees past#2. Being out a full cyl after cam/crank at TDC hasme baffled.
Any ideas would be most appreciated.
<!--SEARCH--><!--POLLS--><!--FILES--><!--SIGNATURE-->
Old May 16, 2013 | 11:40 AM
kevinkpk's Avatar
I think the crank is at 12, and cam at 6.
ccnchevroletforum
Nov 16, 2012 6:48 PM
ARARE66
Feb 24, 2012 8:39 AM
gmuchin
May 11, 2010 4:52 PM
robosimono
Oct 7, 2008 5:34 PM
Camo4x4
Aug 17, 2008 8:32 AM
