Cam, crank, distributor don't match up
1986 El Camino w/305 with 310k miles, all original. The original cam sprocket was nylon, which was cracked.
Would not crank and at TDC distributor pointedat #2. Firing order is: 1 2 7 5 6 3 4 8.
Replaced timing chain and gears w/double roller. With both marks at 12 o'clock, per the manual, the distributor still points a few degrees past#2. Being out a full cyl after cam/crank at TDC hasme baffled.
Any ideas would be most appreciated.
<!--SEARCH--><!--POLLS--><!--FILES--><!--SIGNATURE-->
For Sale: 1970 chevelle ss 396 # match, f41
ccnchevroletforum
Nov 16, 2012 6:48 PM
ARARE66
Feb 24, 2012 8:39 AM
Camo4x4
Aug 17, 2008 8:32 AM
