HVAC module plug
Old Mar 6, 2023 | 1:20 PM
ebxgsxr's Avatar
Default HVAC module plug
So my fan speed **** was acting up. I purchased a remanufactured unit from eBay. It was working great except the heat didn't seem to work as good. So I got a Dorman part from work just to test it. But when I plugged that one in, the fan speed **** did not work at all. I plugged the remanufactured unit in and the fan speed didn't work either.
As I was testing things I found the 4 wire plug that plugs in on one side must not be making a good connection. if I wiggled the wires everything would work. So I ordered a new harness from work. But I noticed that the back of the module doesn't appear to have pins that contact inside the harness. I looked at a new Dorman part and it looks the same way. What is the harness contacting to make the electrical connection?
Is everyone's module like this?
Old Mar 6, 2023 | 8:34 PM
ebxgsxr's Avatar
well, in case anyone runs into this problem.....apparently that plug does nothing for the module. i guess it's for either other features or for modules in other trucks that have different options.
i unplugged the harness completely and was still able to turn on the blower motor. i guess i have a loose connection on the main plug b/c if i tilt the module a certain way, it does not work. but i was able to get everything back together and working so i'm happy.
Newbie mechanic
1988 - 1998 (GMT400)
Mar 10, 2022 3:40 PM
SW Chevy van guy
Aug 31, 2021 3:34 PM
Chevygirl93
14
Feb 2, 2021 11:08 AM
randy4billsn3@Yahoo.com
Aug 21, 2016 10:19 AM
MindRealm
Feb 6, 2016 9:01 PM
