Ignition problem
Old Jan 7, 2019 | 7:32 AM
Mathias85's Avatar
Default Ignition problem
Have a problem with my c1500 1990. No spark at all. And with some troubleshooting i notice that i have 12v power at the coil with no key in the ignition/off, and no power to the coil at run and start?
Can not find any info about this problem anywhere. Anybody with some ideas?
thanks.
Old Jan 7, 2019 | 7:45 AM
Check the ignition switch and the relay.
Old Jan 7, 2019 | 9:46 AM
Mathias85's Avatar
i orderd a New ignition switch, but relay? Runs the power to the coil thru a relay? Where is the location of that?
sorry for the bad english.
Old Jan 29, 2019 | 5:50 AM
usmarine0905's Avatar
@Mathias85.... please keep posting, my 1998 C2500 is having the same problem. Keep us posted on the fix...
Old Mar 5, 2019 | 8:47 PM
Terminal Frost's Avatar
I would suspect an ignition switch is maladjusted ( out of adjustment ) or defective.
But if you have 12 volts at the coil with the key in your pocket, the battery WILL go dead quickly.
Does the fuel pump turn on when you turn the key to the "run position" (not crank) ???
Need more info. This TBI system is simple.
US Marine ( thank you for your service )
Your 98 is a Vortec and a different system all together. What is yours doing ??? I have a 98 as well
Old Mar 6, 2019 | 3:56 PM
@ Terminal Frost..... I have been able to get mine running. Mine was a defective new ignition coil, and I replaced my original distributor with an aluminum aftermarket, and reset the timing. Running strong again with 341,000 miles....
Old Mar 13, 2019 | 8:38 PM
I pulled my C2500 from the grave. One of the 3 issues I found was a defective coil. I have an aluminum replacement distributor as well. Bike Week got in the way last weekend. Maybe install it this weekend :-)
Glad to hear you were able to get yours fixed.
