Instrument Panel Gauge Behaviour
Old Dec 19, 2015 | 7:36 PM
Cowboycoupe's Avatar
Default Instrument Panel Gauge Behaviour
After putting the new thermostat in my 98 5.7 C-1500, I decided to pay attention to the way the gauges behave. I already knew that the gas gauge moved down fast ;-).
The temp gauge moves, it goes from about 150 to around 180 depending on outside temp and load on the truck. Takes quite a while to warm up in cool witner weather. The oil gauge varies from around 55 at cold start, to around 45 when hot at 30 mph. The volt gauge moves a bit, but it usually says 14 V.
Wondering why the truck runs so cool. Also why it takes a while to heat up.Same as the old thermostat, by the way.
Any others want to share what the gauges on their trucks say.
Old Dec 19, 2015 | 9:21 PM
not sure about the 1988 model year but the next body style 99 would set a p0128 if the vehicle took to long to reach operating temp. If there is a p0128 diagnostic for your truck and this dtc is not setting...everything is normal.
Old Dec 22, 2015 | 10:56 PM
cleveland63b's Avatar
if the heater blows hot like it should I wouldn't worry about it
