Jack & Accessory Tray Removal
Old Jun 5, 2025 | 7:31 AM
FifthWheelPuller's Avatar
Default Jack & Accessory Tray Removal
Has anyone been able to figure out how to remove the long center tie-down bolt that holds the jack in the tray under the rear seat of an extended cab?
There is a bolt on the in-board side that is easy to remove, but the other one is the long one that is a threaded rod that extends up high to hold down the jack with a wing nut. I could not see any nut under the vehicle at that point so I do not understand what holds it down.
It has a tiny little hex head that strips out easily, and visegrips on the shaft turn it a little, but not enough to unscrew anything.
google727@mail.com
Nov 28, 2022 8:12 PM
DeanH
Jun 12, 2022 8:25 PM
rwitczak
Jun 30, 2017 2:55 PM
stephen kamphaus
Avalanche
Nov 20, 2016 7:22 PM
Bill's Dad
Jun 22, 2010 5:21 PM
