Just some advice needed please!
Hey everybody so I bought a 92 GMC Sierra 1500 only 97k on it and it’s sat for a while. It started up and ran after just a battery and a little tweaking with the starter wires but It seems to have a pretty hard start now I’m thinking it’s just old gas but I went ahead and did plugs and wires just to be on the safe side. Should I change the pump or injectors? Or just run some sea foam through it and see what happens? Any suggestions on what I should do would be really appreciated, thank you
Thank you, I changed the fuel filter and ran some sea foam. Turns out I had the plug wires off a hair I checked them and put them where they needed to be. It starts fine and really quick when it’s cold but when it’s warmed up I have to put the throttle down to start it. I heard it might be the brain but I don’t know.
oh ok probably wouldn’t hurt. The fuel filter seemed to help when I changed it but I’ll probably check the fuel pump next. Good/bad thing is it ran out of gas when I moved it so the old fuel was more or less gone but the fuel pump didn’t go out, luckily. Thank you
lafitte23
June 2nd, 2009 8:51 PM
