K1500 with 8 bolts
Old Nov 4, 2017 | 5:04 PM
poklop's Avatar
Default K1500 with 8 bolts
Hi, i have question, how possible is 99 Chevy K1500 with 8 bolts? According owner's manual should be 8 bolts on K2500 version.
Thanx.
8 bolts
Old Nov 5, 2017 | 1:20 AM
burnhedge's Avatar
I'm guessing someone replaced the doors or trim with 1500 emblems. No 1500s had 8 lugs or those factory fender flares. Also if that was a 99 1500 it would be the newer body style.
Old Nov 5, 2017 | 11:55 AM
poklop's Avatar
VIN decoder says:
1999 Chevrolet Suburban 1500 4WD
Vehicle NameChevrolet Suburban
Body Style4 Door 1500
Body CodeE55, ZW9
Drivetrain4-Wheel Drive
MFR model codeCK10906
Body typeSport Utility
Old Nov 5, 2017 | 11:58 AM
poklop's Avatar
Friend of mine have 1995 Suburban K1500 with 8 lugs also, so hows it?
Old Nov 5, 2017 | 12:23 PM
burnhedge's Avatar
I thought it was a truck. Not sure what went on with suburbans.
Old Nov 5, 2017 | 12:29 PM
burnhedge's Avatar
Are they diesels? I just read something about k1500 diesel subs with basically a 3/4 drive train.
Old Nov 5, 2017 | 12:53 PM
poklop's Avatar
Yes, they are 6.5 Turbodiesels both.
Do you think it could be the same 3/4ton drive train like K2500?
In this case im not sure with ordering parts such as wheels, brakes, suspension and others...
Old Nov 5, 2017 | 2:55 PM
burnhedge's Avatar
The rpo codes from the glove box will give you alot of info. Even the 2500 trucks have alot of different drivetrain combos.
Dieselplace.com has a couple good conversations on your particular situation.
Old Nov 6, 2017 | 8:00 AM
check the gvwr on the door sticker. 7000lb range is a 1500
the next generation gm made 1500HD models which were 1500 labelled trucks with a 2500 series chassis and powertrain.
Old Nov 6, 2017 | 2:58 PM
poklop's Avatar
door stick 7900lb,
GVWR
i will definitely check the rpo codes and dieselplace
thanx
