K1500 with 8 bolts
Old Nov 8, 2017 | 1:46 PM
  #11
poklop's Avatar
11U : PRIMARY COLOR, EXTERIOR, DK WILLOW SAGE MET (95)
1SC : PACKAGE, OPTION 03
522 : TRIM COMBINATION, LEATHER, LT NEUTRAL (2) (92)
52I : INTERIOR TRIM, LT NEUTRAL (I) (92)
6GK
7GK
A31 : WINDOW, POWER OPERATED, SIDE
A95 : SEAT, FRT BUCKET, HIGH BACK, PASS & DRIVER RECL
AG9 : ADJUSTER, SEAT, POWER, 6 WAY
AJ1 : WINDOW TINTED, DEEP, ALL EXCEPT W/S AND DRS
AS3 : SEAT, RR, SUBURBAN
AT5 : SEAT RR, CTR, FLDG
AU0 : LOCK CONTROL, REM0TE ENTRY
AU3 : LOCK CONTROL, SIDE DR, ELEC
AXP : 844 P VIN IDENT POSITION, MULTI-PURPOSE VEHICLE 890110 P T T A
B33 : COVERING, REAR FLOOR MATS AUX
B37 : COVERING, FLOOR MATS, FRT & RR AUX
B71 : MOLDING WHL OPENING, COLORED
B85 : ORNAMENTATION, EXTR MLDG BELT REVEAL
BVE : STEPS RUNNINGBOARD, SIDE, BLACK
C36 : HEATER, AUXILIARY
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C5I : GVW RATING, 8050 LBS
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C69 : HVAC SYSTEM, RR, AIR CONDITIONER
D48 : MIRROR O/S, REM CONT, ELEC PAINTED
D55 : CONSOLE, FRT COMPT, FLOOR
DF5 : MIRROR I/S, R/V, LT SENSITIVE, COMPASS, O/S TEMP
DK6 : CONSOLE ROOF, INTERIOR
FE9 : CERTIFICATION, EMISSION, FEDERAL
FF6 : ARM, TORS BAR SPRING ADJ (E) - FF6 : 6693 P ARM R ARM LH TORS BAR SPRING ADJ (E) 970507 E T E A
FF7 : ARM, TORS BAR SPRING ADJ (F) - FF7 : 6694 P ARR R ARM RH TORS BAR SPRING ADJ (F) 970507 E T E A
G80 : AXLE POSITRACTION, LIMITED SLIP - G80 : Rear Axle - Positraction
GU6 : AXLE REAR, 3.42 RATIO
JD7 : BRAKE, HYD POWER, DISC/DRUM, 8400 LBS
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K47 : AIR CLEANER HIGH CAPACITY
K68 : GENERATOR,105 AMP
KNP : COOLING SYSTEM TRANS, HD
L65 : ENGINE, DIESEL, 8 CYL, 6.5L. TURB0, HO - L65 : 15440 P ENG M ENGINE DIESEL, 8 CYL, 6.5L, TURBO, HO 980601 E 1 E A
MSL : 16212 P PLT R PLANT CODE SILAO, MEXICO 970425 E M E A
MT1 : TRANSMISSION, AUTO, 4 SPD, THM R2
N33 : STEERING COLUMN, TILT TYPE
NF2 : EMISSION SYSTEM, FEDERAL, TIER 1
NP5 : STEERING WHEEL, LEATHER WRAPPED
NP8 : TRANSFER CASE – (ACTIVE) – PUSH BUTTON CONTROL, 2 SPD
NY1 : SHIELD, FUEL TANK
NZZ : SALES PACKAGE, SKID PLATE OFF ROAD SPOT
P06 : TRIM DISCS, WHEEL
QIZ : TIRE ALL, LT245/75R16/E BL R/PE ST TL ALS
R7K
R7M
SLL : 23736 P SPC R SALES PROCESSING SOLD ORDERS 10209 P T T A
U19 : SPEEDOMETER, INST, KILO & MILES KILO ODOMETER
UL0 : RADIO AM/FM STEREO, CASS. (EUROPE COMPLIANT)
UQ3 : SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
V22 : GRILLE, CHROME, RADIATOR
V27 : GUARDS, BUMPER, FRT,
V54 : LUGGAGE CARRIER, ROOF, PAINTED
V73 : ANTENNA, FIXED
VK3 : LICENSE PLATE, FRT MOUNTING PKG
VXS : VEHICLE COMPLETE
X88 : CONVERSION NAME PLT CHEVROLET
XHH : TIRE FRONT, LT245/75R16/E BW R/PE ST TL ALS 120Q
YD3 : FRONT AXLE, BASE EQUIPMENT FOR SCHEDULING, GVW PLATE
YD6 : REAR SPRING, BASE EQUIPMENT
YE9 : CONVENIENCE PKG, COMFORT & DECOR LEVEL #3
YHH : TIRE REAR LT245/75R16/E BW R/PE ST TL ALS 120Q
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP - 980309 E 7 E A
ZHH : 32660 P SPT R TIRE SPARE LT245/75R16/E BW R/PE ST TL ALS 120Q 970626 E T E A
ZQ3 : SALES PACKAGE, DRIVER CONVENIENCE II
ZW9 : B0DY EQUIPMENT, BASE BODY OR CHASSIS
ZY1 : COLOR COMBINATION, SOLID
