k1500 gears
Old Apr 10, 2016 | 5:35 PM
chevychick76's Avatar
Default k1500 gears
Is there any way I can find out my gear ratio? My front differential is leaking and ism trying to see which one I need to buy to replace it so I can rebuild this one.
Old Apr 10, 2016 | 7:47 PM
burnhedge's Avatar
I don't see the year of the truck in your post or sig. I believe pre 96 all have codes in the glove box. Not sure about 96-98. If your not sure the truck is all original or you can't read the codes you'll have to pull the cover off the rear diff and check the ring gear.
Old Apr 10, 2016 | 8:09 PM
It's a 98. It has the sticker on the box. I just don't know the codes.
Old Apr 10, 2016 | 8:11 PM
Last time I took the diff cover off I wasn't sure of the numbers on the rings. I'm also not sure if it's stock but I think the only thing done was a 6 inch lift.
Old Apr 10, 2016 | 8:48 PM
burnhedge's Avatar
Default k1500 gears
The ring gear will be stamped with two numbers. Say 37 and 9. These are the number of teeth on the ring and pinion gears. 37 divided by 9=4.11 gears.
Rpo codes are available many places online. West coast diffs has a good list just for what your looking for. These are the ones I know by heart for rear ends.
Gu4=3:08
Gu5=3:23
Gu6=3:42
Gt5=3:73
Gt6=4:10
Old Apr 10, 2016 | 10:33 PM
I was hoping I had 3.73 but I'm thinking they are 3.42 which means I'll be wanting to upgrade them. What would be the best suggested ratio?
Old Apr 10, 2016 | 10:57 PM
burnhedge's Avatar
Most k1500's are 3:42.
It depends on a lot of factors,
What size tires you want to run is most important. That way you know what gears will bring you back to stock "power" . Then go from there depending on what you want to do with the truck.
I'm assuming you are running large tires since you mentioned a lift.
Old Apr 11, 2016 | 10:31 AM
It's a 4x4 so yes I'm running 35/12.50/16's. I had 36's and down sized. But of couse I want the power to pull and play pretty much.
Old Apr 11, 2016 | 10:33 AM
Old Apr 11, 2016 | 1:24 PM
burnhedge's Avatar
4:56 would probably be the best choice. May want to do 4:10 if it's a daily driver that you want to cruise down the highway with.
You may have limited choices in a 8.25 front diff, but I would think 4:56 would be available.
