My 91 c1500 is turning off while in gear
Old Sep 29, 2019 | 3:24 PM
Kevinv91's Avatar
New User
Awaiting E-mail Confirmation
Default My 91 c1500 is turning off while in gear
I need to figure out why my truck runs perfectly fine while I’m driving but I’m coming to a complete stop or I am at a stop and try to continue driving it shuts off and I have to put it in park and turn it back on and I drive fine until I come to a stop again
Old Oct 2, 2019 | 2:35 AM
Sabino56's Avatar
I assume you don’t have a check engine light? First thing I’d do is check if there are any codes. Here’s a link with info on how. https://www.chevytalk.org/fusionbb/s...php?tid/273660
if there are codes, follow the trail on that code to fix it. If you can’t figure out how - post question with code and people will help if they have ideas, experience on that particular code/problem.
If no check engine lights or codes, then I would check the basics - fuel pressure and timing. Here’s a link with good info on how https://www.chevytalk.org/fusionbb/s...php?tid/253427
good luck!
Old Oct 2, 2019 | 3:59 AM
oilcanhenry's Avatar
You may have a bad IAC (idle air control). Try eliminating any vacuum leaks (I'd torque the intake manifold bolts down to spec. ) and cleaning the throttle body first. Have someone or a device to hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carburetor cleaner, engine off of course. Be sure to spray some into the small holes next to the throttle plate. If it still has a problem, replace the IAC. I'd also change out the fuel filter too.
William Webb
Feb 2, 2017 11:31 AM
CrashFF
Mar 24, 2014 3:31 PM
Mitch931
Mar 7, 2012 9:17 AM
jose
May 6, 2011 10:19 AM
dusty2689
Sep 21, 2007 10:30 AM
