No Spark No Start 1996 K1500
Old Aug 30, 2020 | 11:50 AM
Chevygirl93's Avatar
Default No Spark No Start 1996 K1500
If anyone has been following my mess of a truck, IAM now broke because of it. I just want to it to start thats all. I'm throwing a crank sensor P0335 code after clearing it. Truck will crank just fine just no spark. Have fuel as well. Have replaced every ignition part twice literally and everything is acdelco. PCM is brand new. I have power to everything including fuses. I have ohmed, voltage, probed, and light checked everything. Coil with light up but no flash.
​​​Expensive scanner still says no spark. Have tried everything. Can someone please help me.
Old Aug 30, 2020 | 12:00 PM
Have you check the wiring harness going to the crank sensor for damage?
Old Aug 30, 2020 | 12:01 PM
I have not took it all the way out of the entire loom. But I did a grounded check on the signal wire to see if it was grounded any where and it wasn't.
Old Aug 30, 2020 | 2:26 PM
kevinkpk's Avatar
What is the history of the ecm, original?
Old Aug 30, 2020 | 2:27 PM
ECM is brand new
Carl Destro
May 15, 2020 11:07 AM
Cornbread9
Mar 18, 2018 6:04 PM
Jason1Tennant
Dec 23, 2013 10:13 PM
acer9876
15
Feb 23, 2013 10:41 AM
andrew4g63
Feb 3, 2008 1:00 PM
