Noise in brakes
Old Jan 6, 2021 | 11:24 AM
blh102444's Avatar
Default Noise in brakes
I have a 1998 1500 2 wheel drive. I was getting a sometimes vibration roaring noise in drivers side front wheel that would stop when brakes were applied. Pads were not nearly worn out but looked glazed somewhat. I sanded then down and it seemed better for awile then started again. I replaced pads and rotors but it hasn't helped. It does not pull or over heat as if caliper is sticking. Any ideas?
Old Jan 7, 2021 | 6:34 PM
burnhedge's Avatar
Bearing noise
Old Jan 7, 2021 | 8:25 PM
blh102444's Avatar
I considered bearings but they probably don't have 1000 miles on them and appeared ok. I repacked them when I did the brakes
Old Jan 8, 2021 | 9:16 PM
blh102444's Avatar
I think I found and resolved the problem. I changed out the wheel bearings today but the noise was still there. As I said the noise (a rasping vibrating sound ) was off and on and would always stop when touching brake When attaching the caliper the bolts go in from the back side. I would fit the scocket on and tighten them till they felt tight. Upon further looking at the bolt heads by sticking my head over the rotor I saw they were not run down as far as bolts on the other wheel even though they felt tight. I was able using a lot of force to run the bolts tighter and after driving a number of miles. NO NOISE!!!! I am assuming the problem started by not getting then very tight last time caliper was off and after several months they backed out enough to vibrate but still feel tight.
xnuke
Dec 23, 2024 1:52 PM
mikeythe613
Jul 17, 2010 7:51 AM
19silverado87
Oct 14, 2009 5:41 AM
HollywoodBush
Jun 13, 2008 6:26 PM
02blue1
May 26, 2007 8:54 PM
