Park start
Old Jun 8, 2018 | 1:53 PM
Db9915's Avatar
Default Park start
1995 chevy k1500. Will start in neutral but not in park. All fuses good brand new neutral safety switch 2nd one. All lights work including reverse lights park light on cluster doesn't light up either everything else is fine. Any ideas would be great thks.
Old Jun 8, 2018 | 2:11 PM
kevinkpk's Avatar
The rod must not be moving the switch all the way. Dis connect the switch from the column, move it to the park position, if it starts the rod needs adjusting, or the switch isn't quite in the right position.
Old Jun 8, 2018 | 2:19 PM
Db9915's Avatar
Ok I changed the neutral safety switch on the trans 4l60e. Which switch are u referring to on the column
Old Jun 8, 2018 | 3:32 PM
kevinkpk's Avatar
Is there not a switch on the column?
Old Jun 8, 2018 | 3:37 PM
kevinkpk's Avatar
1995 the switch was moved to the tranny.
Old Jun 8, 2018 | 3:40 PM
Db9915's Avatar
That's the one i changed twice thinking the first one was also bad I'm at a loss now not really sure what's going on
Old Jun 8, 2018 | 3:50 PM
kevinkpk's Avatar
You can "kinda" see how that is adjusted, and I think that's the issue.
Old Jun 9, 2018 | 9:06 PM
transmission range switch
