Permanent P0A00 code?
Old Jul 7, 2024 | 1:41 PM
Jeremy66's Avatar
Default Permanent P0A00 code?
I have a 1997 Silverado 5.7L 4x4. It is throwing a permanent P0A00 code even after replacing the ECT sensor. You can clear the code and reset computer but it still read Permant P0A00 as soon as you scan with a scanner.
Old Jul 7, 2024 | 11:38 PM
that doesn't appear to be a valid trouble code for your truck: https://charm.li/Chevy%20Truck/1997/...Code%20Charts/
Try a different scanner.
What does your temp gauge say?
Old Jul 8, 2024 | 6:58 PM
Jeremy66's Avatar
Default P0a00
The code stated P0A00 Motor electronics engine coolant temp. On multiple scanners. Ever if you clear all codes then it reads this code without ever cranking the vehicle and says permanent P0A00 code. I’ve replaced both ECT sensors one for PCM and the one for the gauge. I’ve checked all wires everything is fine. Temp reads fine in scanner but reads high on gauge. I drive the truck 1.5hrs to work and it never runs hot I never have to add water or anything.
Old Jul 8, 2024 | 7:01 PM
Jeremy66's Avatar
Old Jul 8, 2024 | 7:24 PM
From service manual
troubleshooting: Temperature Gage Indicates Hot:
https://charm.li/Chevy%20Truck/1997/...dicates%20Hot/
favio
May 26, 2024 3:10 PM
poopster
Site Feedback
Apr 23, 2023 12:53 AM
Jeroen
Site Feedback
Nov 16, 2019 11:23 AM
Momslilangel
Jan 30, 2012 5:20 AM
