Q -- Non-op temp gauge
Old Mar 28, 2021 | 9:45 PM
Autonerd's Avatar
Default Q -- Non-op temp gauge
Hi all -- Question about my '93 C2500 (350 TBI automatic). The coolant temperature gauge stays at full cold. However when I crank the engine it goes to the far right then returns when I release the key. Upper and lower radiator hoses are nice and warm. I believe my wife said the heater blows warm but I haven't checked. The other auxiliary gauges work normally.
I figure the gauge isn't dead since it sweeps when we start the truck. Does this sound like a bad sender? (As opposed to a stuck thermostat?)
Thanks --
Aaron
Old Mar 29, 2021 | 7:25 AM
Sounds like a bad sensor, which should be an easy fix.
Old Mar 29, 2021 | 11:03 AM
hanky's Avatar
Something you might try, with the key on, and the wire off the sending unit, what reading do you get? Then hold that end of the wire to a good ground connection , what reading do you get now?
Old Mar 29, 2021 | 2:10 PM
Autonerd's Avatar
I will try that and post results -- thanks!
john2000
Apr 26, 2020 12:41 PM
Sonicd
May 13, 2013 2:48 PM
BMacleod
Mar 13, 2011 12:09 PM
jffgin
Mar 2, 2008 10:26 PM
kjmattakat
Aug 13, 2007 9:29 PM
