Rear end compatibility
Old Nov 26, 2022 | 1:34 PM
tcarstens67's Avatar
Default Rear end compatibility
I have a 97 Chevy k1500 5.7 z71 truck and I also have a 03 GMC 1500 5.3 z71both are 10 bolt rear ends. Can I swap the 03 rear end into my 97?
Old Nov 27, 2022 | 10:04 AM
Gumby22's Avatar
The whole axle assembly or just the differential?
Old Nov 27, 2022 | 10:10 AM
[QUOTE=Gumby22;484862]The whole axle assembly or just the differential?[/QUOTE
The whole axle assembly is what I would like to do.
Old Nov 27, 2022 | 1:21 PM
Gumby22's Avatar
The first step is to verify the gear ratio.
In the glove box of each truck is the RPO sticker. Compare the codes that start with G - one defines the gear ratio and the other defines if it’s limited slip.
If the gear ratio codes match, a swap is possible.
You’ll then want to compare the following measurements:
Axle mounts center to center - determines if the axle will bolt in place.
Axle flange (wheel hub flange) face to face - determines if the wheels will have the same spacing or be inboard/outboard relative to the original axle.
Driveshaft comparison - easiest by removing both and lying them side by side. Look at overall length, slip yoke size, and u-joint dimensions. Depending on the differences you may have to have to a driveshaft shop modify one to fit.
Old Nov 27, 2022 | 1:24 PM
Thank you so much I will do that to compare.
Lazersc24
Jul 4, 2022 9:10 PM
Evan Young
Nov 25, 2016 11:21 PM
wis2ohio
Jul 13, 2013 4:14 PM
k1500guy
Nov 15, 2011 8:43 PM
Bolander
Nov 24, 2007 7:09 PM
