Replace Rag Joint?
Old Jan 18, 2021 | 6:27 PM
superdave67's Avatar
Default Replace Rag Joint?
There is a lot of play in the steering wheel of my 90 Chevy C1500 (5.7). I believe it to simply be the rag joint or steering coupler that has worn out. In some other forums, I saw that you can't replace the coupler in the steering shaft of the 1990 Chevy C1500. Is that true? Can I simply buy a new coupler and replace the stock one? Or do I need to buy the entire shaft assembly?
Also, if I wanted to get away from the bushing/coupler and use a U-joint swivel connector... what would be a good steering shaft?
Thanks all,
Dave
Old Jan 19, 2021 | 7:21 AM
Welcome from Florida. Rockauto has what you need.
https://www.rockauto.com/en/catalog/...g+coupler,7418
Old Jan 19, 2021 | 7:52 AM
Thank you! So I assume then that they CAN be replaced... cool. Thanks again, I'll order that today.
Dave
dh1
Sep 30, 2015 5:14 PM
rjdjbd
May 2, 2014 5:58 PM
dp77/00vette
Feb 19, 2012 4:18 PM
chevy_girl007
Colorado
Aug 31, 2010 7:54 AM
94burbin
Jun 8, 2009 8:06 PM
