Rod knock???
Old May 27, 2023 | 8:17 PM
OBS Guy's Avatar
Default Rod knock???
Just rebuilt my 5.7 vortec. Replaced everything. Everything except the pistons and rods. I had two that were seized so I replaced #1 and #2. Put it in the truck and it had a rod knock. So pulled the pan and replaced every bearing in the truck. They had a few scared, but didn’t look bad enough to cause a knock. Cranked it and it still had the exact same rod knock. The knock is on the new #2 cylinder it sounds like. Am I actually hearing a rod knock or is it something else. Thought I would get some thoughts on it before I tore it back apart. Any info will help.
Old May 28, 2023 | 8:31 AM
kevinkpk's Avatar
Did you check piston to cylinder tolerence?
Old May 28, 2023 | 9:15 AM
OBS Guy's Avatar
No I didn’t. I put the exact same size rod and piston that came in the motor. So that was the last thing I was thinking about.
booglemackey
Aug 30, 2016 12:49 PM
winkie74
Nov 22, 2012 12:18 PM
DragonSlayer
Nov 8, 2009 3:35 PM
lgarner
Aug 26, 2008 6:39 PM
