Shaking for 4 or 5 seconds
I’ve got a c2500 .. while I was driving yesterday it shook violently for 4 or 5 seconds
no check engine
drove 2 miles to my house just fine
then I drove it to work this morning 30 miles , without any problems
what can this be … and that’s the first time it hampened
it hampened wile I was on the gas at about 20mph
no check engine
Full and mabe 70 degrees
drove home just fine as well another 30 miles
last night I went back by we’re it hampened ,to double check the road and it was nice and smooth
no check engine
no check engine
There are a lot of possible explanations, especially if it’s only happened once.
Start by checking fluids in the transmission and rear diff and check for damage to the driveshaft and tires.
Inspect the shocks, coil springs and leaf springs for damage.
Chock the wheels, shift to neutral with the key on, engine off, and inspect the u-joints for play.
Get the wheels off the ground and rock the tires top to bottom to check for loose wheel bearings - this will also check for movement in the ball joints.
1995suburb
October 1st, 2024 5:21 AM
