Shaking for 4 or 5 seconds
Old Nov 19, 2021 | 11:26 AM
jack2784268's Avatar
Default Shaking for 4 or 5 seconds
I’ve got a c2500 .. while I was driving yesterday it shook violently for 4 or 5 seconds
no check engine
drove 2 miles to my house just fine
then I drove it to work this morning 30 miles , without any problems
what can this be … and that’s the first time it hampened
it hampened wile I was on the gas at about 20mph
Old Nov 20, 2021 | 7:23 AM
Mr. Dude with a face's Avatar
That is very strange. What was the weather like? And how much fuel was in the tank?
Old Nov 20, 2021 | 8:25 AM
Full and mabe 70 degrees
drove home just fine as well another 30 miles
last night I went back by we’re it hampened ,to double check the road and it was nice and smooth
Old Nov 20, 2021 | 9:36 AM
Was it raining? I was just wondering if it was a moisture issue.
Old Nov 20, 2021 | 9:44 AM
My bad mabe it was 50 or 60ish degrees
it was foggy .. no rain though
Old Nov 20, 2021 | 11:20 AM
I don't know. Maybe @Gumby22 will know...
Old Nov 20, 2021 | 11:33 AM
I tried sending a message but it won’t let me
Old Nov 21, 2021 | 8:46 AM
Gumby22's Avatar
no check engine
Did you notice if the truck happened to be shifting at the time the shake occurred? What about any sudden change in speed? Pulling left or right?
There are a lot of possible explanations, especially if it’s only happened once.
Start by checking fluids in the transmission and rear diff and check for damage to the driveshaft and tires.
Inspect the shocks, coil springs and leaf springs for damage.
Chock the wheels, shift to neutral with the key on, engine off, and inspect the u-joints for play.
Get the wheels off the ground and rock the tires top to bottom to check for loose wheel bearings - this will also check for movement in the ball joints.
1995suburb
Oct 1, 2024 5:21 AM
matthewbellah
Jun 19, 2021 12:59 AM
Kbsjbk
Dec 31, 2018 2:35 PM
Chris511
Mar 12, 2017 4:41 PM
zack3439
Camaro
14
Jul 28, 2015 7:25 AM
