Surge After Shifting
Old Jan 16, 2021 | 1:45 AM
Red 94's Avatar
Default Surge After Shifting
Hello,
I have a '94 K1500 with a 4.3L and NV 3500 transmission and I've noticed a strange surge, or jerking, sensation after I shift to the next gear when driving. When it's cold and has just started to get on the road, it's fine. After everything has warmed up, I'll grab a gear and the truck starts to jerk around and sounds like it's losing it's fuel supply and trying to shut down on the highway. Once in a while it will surge while at a cruising speed too. I have recently replaced the fuel pump and the fuel filter, and the air filter looks decent. I was just hoping to pick your brain and see if you had any ideas that I could check out. Thanks for any help!
Old Jan 16, 2021 | 4:46 AM
oilcanhenry's Avatar
Originally Posted by Red 94
Hello,
I think you have a bad Throttle Position Sensor (TPS) on your Chevy..
Old Jan 16, 2021 | 7:48 PM
Mr. Dude with a face's Avatar
@oilcanhenry How would that cause the surge? Would it be caused by a dead spot in the sensor, so every time he hits that spot it stumbles? I think it is safe to assume he has good fuel supply, but we should also consider the truck would have TBI, right?
Old Jan 17, 2021 | 3:12 PM
Red 94's Avatar
Yes the truck has a TBI set up. Where it was happening when I let the clutch out I was wonder if it could possibly be the clutch or the pressure plate. I keep forgetting how many sensors are on these trucks.
Old Jan 18, 2021 | 9:41 AM
TBI has a Throttle Body Sensor.
Old Jan 18, 2021 | 9:43 AM
Post some OBD I codes if you can.
Old Jan 19, 2021 | 12:12 PM
Red 94's Avatar
I haven't noticed any lights coming on when it does that. Could there be codes if there are no warning lights?
Old Jan 19, 2021 | 5:42 PM
Yes there can be.
Old Jan 20, 2021 | 3:14 PM
Red 94's Avatar
Sounds good. I'll see what I can find. Thanks for the help
Old Jan 23, 2021 | 4:06 AM
No problem. That's what we are here for, Red 94..
