Transmission
Old Mar 16, 2020 | 10:27 AM
Rowdy Goodwin's Avatar
Default Transmission
What transmission would a 1993 Chevy K1500 5.7 ext cab short bed auto have?
Old Mar 16, 2020 | 2:27 PM
Little Bear's Avatar
Thinking they were still 700R4's then, around that time was the transition to the 4L60E.
Old Mar 16, 2020 | 5:01 PM
thank you. Do you know what the difference is?
Old Mar 16, 2020 | 5:44 PM
700R4's shift hydraulically.
4L60e shifts electronically. Requires a control module.
Old Mar 16, 2020 | 5:52 PM
Chris94's Avatar
Do you have easy access to the transmission? It should have an identification tag and/or number on it. I also found this article that explains the differences between the 700r4 and 4l60e.
https://www.monstertransmission.com/...on_ep_113.html
Old Mar 16, 2020 | 7:03 PM
I can't read the tag as it's buried in snow. Does one shift harder? Cuz it seems to shift pretty hard.
Old Mar 16, 2020 | 7:16 PM
negligibly. Transmissions shift harder as they wear down.
Old Mar 16, 2020 | 10:24 PM
Rednucleus's Avatar
If it's any help my 93 Suburban with 5.7l has the 4L60e; 1st one died after 200k; so far 2nd one good at 350+
Old Mar 16, 2020 | 11:20 PM
why do you ask? Are you going to replace it? If you're going to buy it from a rebuilder, then they should know.
Old Mar 26, 2020 | 4:21 PM
It went out so I'm thinking about one from monster transmission and building the truck up more.
