Where is the ground for the coolant sensor by thermostat housing
Old Sep 18, 2024 | 7:18 PM
EzRadDad's Avatar
Default Where is the ground for the coolant sensor by thermostat housing
5.7 TBI, Replaced coolant temp sensor, runs better but will still die when put in drive or reverse, want to check the ground for the temp sensor.
truck will turn over and idle decently. Injectors seem to be spraying as they should. I guess next test is fuel pressure?
new -
cap and rotor
Plugs and wires
Ignition coil
EGR
cleaned PCV
fuel pressure regulator
oil filter
fuel pump
Old Sep 18, 2024 | 9:19 PM
jfmorris's Avatar
A lot of sensors on the engine ground through the body of the sensor, to the engine block. That said, I think the coolant temp sensor has two pins, which most temp sensors do, as they provide a variable resistance or thermocouple type load to the computer in order to produce a reading. The sensor itself likely doesn't use ground.
EzRadDad
1988 - 1998 (GMT400)
Sep 16, 2024 10:17 AM
Johnace54
Aug 31, 2021 10:27 AM
derby311
Jun 20, 2012 2:35 PM
Fuss Butt
Dec 5, 2011 10:35 AM
MDTAHOE
Aug 24, 2011 8:12 PM
