00 o2 sensor issue
Old Feb 1, 2023 | 6:45 PM
Craig_2000silverado's Avatar
Default 00 o2 sensor issue
So I’m a little stumped and don’t want to just throw parts at it but my truck is throwing P0134, P0151 and P0131, it has a brand new O2 sensor and didn’t help fix anything any help?
Old Feb 1, 2023 | 10:49 PM
chem_man's Avatar
15 Year Member
What year Silverado and engine are you referring to?
From the codes, it appears that both banks are having O2 sensor difficulties. When I looked up the codes, it looks like the commonality is electrical. So, look over the wiring that goes to all of your O2 sensors (there are 4) and make sure that the wiring is intact and not melted or shorting out between the O2 sensor's electrical connector and the ECM/PCM. If you have performed any work on the engine towards the firewall or had a shop do work for you, be sure and look that area over really well.
You will be looking for something like melted wiring insulation, a broken wire, wires rubbing against the engine or other metal object, broken electrical connectors, etc.
Good Luck!
Old Feb 1, 2023 | 10:55 PM
It is a 2000 5.3, the previous owner had the rear o2 sensors deleted and tied up so guess I will start with chasing down the wiring diagram for the sensors
Old Feb 2, 2023 | 9:52 PM
chem_man's Avatar
15 Year Member
Look over all the wiring for the O2 sensors - including the ones that the previous owner "bypassed"
You can find wiring diagrams here:
https://mcdowellpubliclibrary.org/chilton-auto-repair/
Good Luck!
Old Feb 2, 2023 | 10:10 PM
So, going to get under and look at wiring tomorrow but as of now I replaced my intake manifold gaskets as I found when I pulled intake to inspect it they were original, went for a drive everything was good but idling parked it threw p0134 and p0131 so the wiring is what I will be doing tomorrow
Old Feb 3, 2023 | 10:03 PM
chem_man's Avatar
15 Year Member
Good Luck!
case310350
Cobalt
Oct 27, 2019 9:41 AM
suburban2003K
Jul 18, 2014 11:13 AM
mcstein
May 10, 2012 11:27 AM
gribble
Sep 14, 2010 6:41 AM
joecoolnow
Oct 29, 2007 10:37 AM
