2005 Silverado 4WD troubles
Old Feb 2, 2023 | 3:35 PM
cody.kostenko's Avatar
Default 2005 Silverado 4WD troubles
I recently bought a 2005 silverado with the 5.3. The rear diff was out and it was cheaper to replace the whole rear axle with a used one than to buy a new diff. Also it had 4:10 gears and I didn’t care for that so I found a rear axle and front diff with 3:73’s. After I got all that installed the 4wd is giving me problems. I click the button for 4 Hi and it blinks a few times and then lights up. Normal. On jack stands it looks like it works. But in the snow only the rear wheels spin. Now when I push 4 Lo same thing but there is a clunk but on jack stands the front tires don’t spin. Neither does the front drive shaft so it isn’t a front diff problem. So what I’m wondering is does the t case need rebuilding or is there some easier fix I can’t find. Thanks in advance.
Old Feb 4, 2023 | 2:42 PM
what tcase you have? have the tcase module code read and post them here
depending on your build....unplug and remove the encoder motor....move the shaft end on the tcase with a wrench to manually perform the 4wd shift....drive it to see if the front prop shaft moves
Old Feb 6, 2023 | 10:49 AM
The t case is an np246. The pickup has no codes.
Old Feb 6, 2023 | 6:52 PM
tccm will set chassis codes so a cheap scan tool can't access them...full function scanner required.
JoeMan
Nov 16, 2021 10:42 PM
Randy3010
Jul 26, 2016 8:12 AM
bouch1989
Feb 18, 2009 11:42 AM
monteash
Oct 2, 2007 11:19 PM
outlaw
Jun 9, 2006 8:13 PM
