01 Silverado 4x4
Old Jul 23, 2025 | 4:08 PM
Jers420's Avatar
Default 01 Silverado 4x4
So the truck worked fine until yesterday when I got out of work, I reversed put it in drive drove home went to reverse but no reverse. So I drive down the street to turn around now I only have 1st and maybe 3rd or 4th not sure. Had the wife get in the truck and put into reverse and the drive shaft doesn't spin but I hear a noise where the drive shaft goes into the transfer case and there's a little bit of fluid around ther too. Any help would be appreciated. TIA.
Old Jul 26, 2025 | 1:54 PM
jw11432's Avatar
Surely I'm not the only one who sees there's no text written?
I highlighted the area and see that you've chosen to use the font color that matches the background color, so the text is invisible. You should edit your post and changed the font color.
But your first steps should be checking the fluid level in both your transmission and transfer case. If that's good, check for codes (it won't necessarily trigger a service engine soon light), so you'll need a scanner that can scan more than just P-codes. Start there and report back.
Earlbolf22
Oct 21, 2022 7:15 PM
grumpychevy
16
Mar 22, 2020 8:43 PM
nicknitro125
Aug 27, 2013 7:53 PM
littleg639
Aug 22, 2013 5:43 PM
breakyadown89
Jan 30, 2010 10:39 PM
