AC "quick recharge" canisters
Old Jul 27, 2025 | 2:07 PM
TigeInGA's Avatar
Default AC "quick recharge" canisters
2004 Silverardo LS.
My AC is weak on the cooling. I'm not sure if I can try the the "quick recharge" canister route. Is there are process I need to follow - how do I do it?
Old Jul 27, 2025 | 2:45 PM
jw11432's Avatar
If there's still refrigerant in it, yes, you should be able to charge it, but this means you likely have a leak, so recharging it is a band aid.
The DIY-friendly canisters with the built in hose and port connector are over priced, but if you don't anticipate needing to do AC work often and don't want to invest in a proper manifold gauge set etc, then they will get you going. A very concise instructional video can be seen here:
Old Jul 27, 2025 | 5:47 PM
Rednucleus's Avatar
It will probably cost you more in the long run vs having a good a/c shop diagnose & fix properly.
tank1949
Jun 29, 2025 9:31 AM
GeneveConversionVan
11
Oct 17, 2020 1:03 PM
radar1234
Jun 26, 2018 1:55 AM
Perigot
Jul 2, 2017 8:29 PM
klemeeri
Jan 11, 2012 5:37 PM
