03 oil leak
Old Mar 10, 2024 | 6:43 PM
h_ponygirl's Avatar
Default 03 oil leak
03 Chevy 2500 has an oil leak only when running and it drops down consistently from the starter bolt closest to the transmission. I bought a scope to try and see where it’s coming from. Can see the stream of oil running down the curve of the starter, but cannot for the life of me see where it’s coming from. Any advice is appreciated. Hoping someone has dealt with this before. I thought is was the crankcase sensor after watching a YouTube video of a truck the same year doing the same thing. Was not it.
Old Mar 11, 2024 | 3:41 PM
chem_man's Avatar
15 Year Member
Check the oil pressure sending unit located on top of the engine behind the intake manifold.
Here is a link to a youtube video showing how to replace it.
If bad, I suggest replacing it with one from GM Genuine, Standard Motor Products (non T series), NAPA Echlin, Delphi, or BWD (non P series).
Good Luck!
Old Mar 11, 2024 | 3:43 PM
h_ponygirl's Avatar
I already did that. It was actually the first thing I replaced.
Old Mar 12, 2024 | 12:49 AM
chem_man's Avatar
15 Year Member
OK on the oil pressure sending unit.
Have you checked the tightness of the valve cover bolts?
Old Apr 20, 2024 | 1:11 PM
Msp5410's Avatar
Hi h_ponygirl-
I have a 2004 Chevrolet Silverado
2500HD and i had the same issue. It's your valve cover gasket, it leaks from the back and runs down. I just did my oil pan gasket, oil cooler lines/gasket, oil pressure switch, oil level sensor and i still had the leak. I was going nuts trying to find it, finally i seen it when it was running it was seaping slowly. Replaced valve cover gaskets both sides and while i was there i put new plugs and wires as well.
Good luck with yours.
Desertrat94
1988 - 1998 (GMT400)
Jun 12, 2018 1:09 AM
Josh2
Aug 19, 2014 6:13 AM
BigRed922
Feb 14, 2014 10:19 AM
BurbanMCS
Apr 20, 2013 12:38 AM
ChevyChic
Oct 4, 2009 12:04 AM
