Do I need to perform a crankshaft position sensor relearn
Old Apr 21, 2024 | 7:56 AM
KeithGist's Avatar
Default Do I need to perform a crankshaft position sensor relearn
Hi, Question. I have a 2004 Chevy Silverado 2500hd 6.0. If you replace the cam and crank shaft sensors do you need to perform a relearn procedure so they work properly?
Old Apr 21, 2024 | 8:47 AM
Gumby22's Avatar
It’s recommended to perform a relearn whenever one or both sensors are replaced.
This can usually be accomplished without a scan tool by disconnecting the negative battery cable for about 15 minutes, then driving at highway speeds for about 5 miles after the engine reaches operating temp.
Old Apr 21, 2024 | 9:27 AM
KeithGist's Avatar
Thank YOU!
Mikewhiteman
Aug 6, 2023 11:24 AM
BoredX
Sep 21, 2020 5:16 PM
BoredX
Jun 28, 2020 9:40 AM
adnildell
Sep 7, 2010 6:22 PM
