Do I need to perform a crankshaft position sensor relearn
Hi, Question. I have a 2004 Chevy Silverado 2500hd 6.0. If you replace the cam and crank shaft sensors do you need to perform a relearn procedure so they work properly?
It’s recommended to perform a relearn whenever one or both sensors are replaced.
This can usually be accomplished without a scan tool by disconnecting the negative battery cable for about 15 minutes, then driving at highway speeds for about 5 miles after the engine reaches operating temp.
