03 z71, no front brakes?
Old Aug 11, 2023 | 9:26 PM
TNofsinger's Avatar
Default 03 z71, no front brakes?
2003 z71 1500
I've replaced front calipers,rotors,pads, and brake hoses. And when trying to bleed the brakes I'm getting good strong fluid to the rear calipers but zero fluid to both front calipers. I've also done new master cylinder.
I've tried doing the automated abs module bleed with a scanner, and still no fluid up front. I'm stumped. Anyone got any suggestions??
Old Aug 11, 2023 | 9:46 PM
Did you put the calipers on the correct sides? Bleeders pointing up?
You might have collapsed flex hoses or a faulty master cylinder.
Old Aug 11, 2023 | 10:03 PM
TNofsinger's Avatar
yes calipers are in the right positions, could be a faulty master but I figured it was good cause I'm getting fluid to the rear. I've read where the proportioning valve could be causing my problem. Im gona try putting a new proportioning valve on and see if it fixes it soon
Old Aug 11, 2023 | 10:44 PM
some MC's have separate seals and valves for front and rear.
Yes, if you have a PV that could be the culprit
one87monte
Oct 24, 2023 8:46 AM
chasx
Jan 26, 2023 11:21 AM
4timechevyman
Aug 6, 2022 12:20 PM
cmoore002
Apr 29, 2010 12:07 PM
dozuki
Feb 5, 2010 11:58 AM
