04 sierra 4L80e shifting problems
Old Dec 24, 2017 | 3:10 AM
Driftguy123's Avatar
Default 04 sierra 4L80e shifting problems
what's up guys I have a 2004 sierra 2500hd 6.0 with a 4L80e tranny, same thing as a chevy haha. It's throwing the code P0502 (vehicle speed sensor low input) I changed both speed sensors, 1 on the transmission, 1 on the transfer case, problem is still there. Changed the fluid and filter too. Also has abs light saying all 3 abs sensors circuit malfunction, and service brake system light is on. It's shifting really hard, it's in fail safe boosting line pressure to max. Just wondering if anyone has had a similar problem. It shifts smooth in 4wd though, shifts hard in 2wd and shifts too early.
Old Dec 24, 2017 | 8:15 AM
the code is for the output speed sensor...which is the one on the tcase
at this point check the continuity of the wiring from the pcm to the sensor.
-key off, unplug the speed sensor and pcm connectors (conncector c2 pin 20 green black and pin 21 purple white wire
-ohm check the wiring for high resistance, opens, short to grd
Old Nov 12, 2019 | 1:11 PM
Thanks for the reply, even though it’s a year later. I was able to fix that problem but now a year later the code is back as well as the symptoms. If all sensors are new and wiring is intact, is it a possible there is a mechanical problem with the transmission?
silveradoman01
12
Jul 1, 2021 11:14 AM
John6275
Jan 7, 2020 7:22 PM
kennykenny
Nov 6, 2018 7:51 AM
blackeagle
Apr 23, 2016 3:56 PM
tompitomas
Feb 9, 2014 11:06 PM
