04 Silverado
Old Sep 14, 2024 | 5:11 PM
PM 43's Avatar
New User
Awaiting E-mail Confirmation
Default 04 Silverado
How do I turn off the check engine light noification?
Old Sep 15, 2024 | 3:28 PM
jw11432's Avatar
By addressing whatever problem it is trying to notify you about lol
A cheap scanner will easily tell you what the issue is, at least at a high level. From there, you can google what tend to be common fixes for your vehicle for said trouble code. That's going to be the easiest place to start. But be sure to not neglect checking the simplest things first: ensure all fuses, especially ones related to the circuit(s) related to your trouble codes, are good. Second, it's never a bad idea to go through every single ground you can find, unbolt it, wire wheel it clean and rebolt. It's remarkable how many problems stem from bad grounds, which easily go bad from corrosion, dirt and/or rust.
Old Sep 16, 2024 | 10:46 AM
jfmorris's Avatar
If you don't have the tools to do it yourself, I would go to a parts store such as Autozone, Advanced Auto, etc, and have them read the codes that are causing the check engine light. They can also clear it, but it won't stay off until the underlying conditions are fixed.
Chevyinthe412
Mar 12, 2022 6:08 PM
Ad Bu
Sep 17, 2021 12:09 PM
Beanstalk13
Apr 16, 2011 8:30 PM
jeffscause
Jul 29, 2008 6:46 PM
haeusser
Feb 11, 2006 8:48 PM
