05 chevy runs 20 min then shuts down
Old Dec 22, 2018 | 7:15 PM
Josh h's Avatar
Default 05 chevy runs 20 min then shuts down
My 05 silverado shuts down after 30 min cranks but won't start I let it sit over night then is starts perfect next day I have proper fuel preasure and can hear pump prime but acts like no fuel anyone see this happen also a week ago my cooling fans started running all the time even when truck is off
Old Dec 22, 2018 | 9:16 PM
oilcanhenry's Avatar
Sounds to me like a heat build up issue. Could be the fuel pump or one of the ignition parts going south.
Old Dec 22, 2018 | 11:25 PM
Josh h's Avatar
I'm going to change all cooling sensors tomorrow
Old Dec 23, 2018 | 2:29 PM
Sure glad my 1998 K-1500 has a typical old-style fan with a shroud.
Old Dec 23, 2018 | 3:23 PM
Josh h's Avatar
Default Changed sensors
I changed cooling temp sensor fan switch all relays still won't run I have spark fuel and compression any ideas?
Old Dec 23, 2018 | 5:50 PM
kevinkpk's Avatar
What is the fuel pressure?
Old Dec 23, 2018 | 6:16 PM
Josh h's Avatar
Default 60 psi
Coils are good ignition is good but im not getting spark
Old Dec 23, 2018 | 7:46 PM
kevinkpk's Avatar
At that point, and intermittent, without spark, PCM?
Old Dec 23, 2018 | 7:50 PM
Josh h's Avatar
Either pcm or ignition control is all I can guess
Old Dec 24, 2018 | 3:54 PM
Josh h's Avatar
Default Changed ignition
Still the same scrap shuts off won't run for 12 hrs I'm looking for a used computer now just to check it
