05 silverado bucks,jerks, then dies! HELP
my 05 silverado 205k miles just started running like it has a horrible misfire. itll buck and jerk on accelerating from a stop then will dies ive replaced the fuel pump, cps, plugs, and wires.
My mechanic was able to get it to drive normal for the last 6 months by resetting my computer but sadly today i had to be towed a mile from home back home after driving about 30 miles to and from work. someone please point me into the right direction.
Check your ignition coils. You should be able to test them using a Digital Multi-Meter (DMM) set to ohms. The primary side will show a low resistance (a few ohms) and the secondary side will show much higher resistance.
Also, you should be able to find what the resistance specifications are here:
https://charm.li/
Good Luck!
https://charm.li/
Good Luck!
https://charm.li/
Good Luck!
https://charm.li/
Good Luck!
Mitnelson
Jul 6, 2014 4:05 PM
tj71
Jun 11, 2014 3:57 PM
