2000 Chevy 1500 misfire
Old May 21, 2023 | 2:35 PM
Jmccall47's Avatar
Default 2000 Chevy 1500 misfire
So I have done just about everything I can think of checked fuses, replaced coils, plug wires, plugs, and it’s still misfiring on cylinders 3-7-4-8 I’m clueless about what to do now. I talked to a guy and he said maybe lifters or cam but the motor has no noise whatsoever any help would be appreciated.
Old May 21, 2023 | 3:36 PM
Please read the big red text at the top of the page that says "This section is not for help threads. "
Moving your topic to pickups
Old May 22, 2023 | 11:26 AM
chem_man's Avatar
15 Year Member
First, a couple of questions.
Which engine is in your truck?
What brand ignition coils did you install?
What brand and part number of spark plugs did you install?
What are all the Diagnostic Trouble Codes (DTCs) that are present?
Without knowing more, I would suggest looking over the ignition coils wiring harness and the fuel injectors wiring harness and look for something like a broken ground wire. Something that is common among those 4 cylinders.
What is interesting is that the the cylinders are across from one another and not on the same bank.
Good Luck!
Leont
Jan 16, 2021 7:48 PM
zomonsta
Mar 28, 2015 12:20 PM
Express
Oct 30, 2012 10:44 AM
ericker
Sep 19, 2010 7:54 AM
Daniel
Mar 18, 2005 12:56 AM
