2000 silverado 2500
Old Aug 12, 2019 | 5:31 PM
1jimbo's Avatar
Default 2000 silverado 2500
got a code of po449 started checking things out and found that my evap vent valve solenoid is not opening or closing . I removed the vent valve checked the power at the connector it's got 12.50 volts and at the battery there is 13.40 volts. so I tested the valve at the battery the solenoid is working but when I go back to the connector nothing. so I rewired the connector it just want open or close . what the heck else could it be? 12.50 should be enough to operate the vent valve. I've checked the ground . HELP
I also bought another valve and it does the same thing. well after some looking I ran a ground wire from the battery back to the connector at the vent valve and it works so I guess I lost my ground ?
mojofly64
2007 - 2013 (GMT900)
Jan 26, 2017 8:13 PM
Dsr122076
Avalanche
Apr 25, 2012 8:55 PM
BillL
Mar 15, 2011 8:33 PM
Red Ron
Mar 30, 2010 4:54 PM
JRT600
19
Jun 4, 2009 11:44 AM
