2000 Silverado 5.3 2wd stuttering/hesitating?
Old Jul 11, 2022 | 3:23 PM
Carsonmartinez's Avatar
Default 2000 Silverado 5.3 2wd stuttering/hesitating?
I have a 2000 Silverado with the 5.3. Recently after changing out some o rings for the ac system and filling it back up I've had a weird issue pop up (not sure if its a coincidence or not). When driving from about 10-30 mph it'll do this thing where the temperature gauge drops and the truck will almost stall (or sometimes actually stall) i can have the petal to the floor and it does not even rev when doing this. I can let my foot off the gas and let it coast for a few seconds it stops, i did replace the spark plugs and wires a few months ago and it has a new fuel pump.It does not drop fuel pressure when this happens. Any suggestions on what to check? The check engine light turns on every so often with a P0332 knock sensor circuit low input code and i don't think its a fuel issue so im a little stuck, thanks.
Old Jul 12, 2022 | 1:18 AM
chem_man's Avatar
15 Year Member
Go back over your AC work and make sure all the electrical connectors you might have disturbed are seated properly.
Good Luck!
simcoe
Apr 27, 2019 1:53 PM
00chevy1223
Mar 14, 2014 5:41 AM
mphayes
Aug 25, 2008 10:49 AM
Houston36
20
Mar 3, 2008 8:22 PM
pyrofytr
Jul 10, 2006 8:38 PM
