2000 silverado 5.3 4x4
Old Apr 30, 2021 | 11:02 PM
Brandynn Moore's Avatar
Default 2000 silverado 5.3 4x4
I can't find where my oil is leaking from, it is dripping down onto my tranny linkage and onto driver side exhaust after the cat, any help would be greatly appreciated 🙏
Old May 1, 2021 | 11:32 AM
chem_man's Avatar
15 Year Member
Go to Advance Auto, O'Reilly, or Autozone and use their loaner leak detection tool kit. First, you'll have to purchase an ounce or so of uV dye that is compatible with motor oil (under $10), add it to the engine's crankcase, and then drive around normally for a hundred or so miles. Park your truck in a garage (or in a shaded spot) then using the uV light in the kit, look all over the engine until you see the origin of the leak.
One common area to check first is where the oil pressure sending unit/switch is located behind the intake manifold. Those are known to leak after time.
Good Luck!
Cam 1500
Feb 17, 2016 4:57 PM
jonathannelson
Apr 18, 2014 5:28 PM
00chevy1223
Mar 14, 2014 5:41 AM
jcliff47
Jun 14, 2011 10:30 PM
ukrkoz
Nov 22, 2010 10:41 AM
