2000 Silverado Auto headlights
Old Aug 25, 2017 | 9:22 AM
shanezoid's Avatar
Default 2000 Silverado Auto headlights
I have a 2000 Silverado LT 4X4. The auto headlights stopped working a little while ago. When you cut the ignition on the lights come on whatever time of day it is. The sensor on the dash has been replaced, the headlight switch. I can find nothing wrong. When you apply the emergency brake before you turn the ignition on they don't come on as they shouldn't or so I have read. I don't want to disable this option. I want to fix it!!!!!!!!! Any ideas or help would be greatly appreciated. Thanks Shane.
Old Aug 25, 2017 | 10:00 AM
Possibly shorted wire to the dash sensor. Also check your relays.
Old Aug 28, 2017 | 11:44 AM
hicksvilleshick's Avatar
Agreed. Something has gone wrong with your daylight sensor...
Old Aug 31, 2017 | 4:45 PM
shanezoid's Avatar
Sensor replaced twice. Checked with a meter and is working correctly. Thanks.
Old Sep 1, 2017 | 7:57 AM
The sensor can work properly but if there is a shorted wire you will have a problem.
Old Sep 2, 2017 | 1:14 PM
shanezoid's Avatar
I think this is my problem. I measured the wires on the plug going into this board and I can see the resistance change. What is this any ideas??
Old Sep 3, 2017 | 1:06 AM
It is the BCM. Body Control Module.
